Skirting Island Dragway NHRA rules
Didn't think I had any mods listed, but it ain't going nowhere unless I can plant it with a 60' under 1.5 secs. Stock ZR1s run mid 10s, bone stock, street tires and a good tune. That's maybe 600hp at the wheels with way too much bottom end to hook it on street tires. I should be +200hp with most of it coming in above 4,000 so hope to be 9.9x with a 1.4 60' or 10.2x with a 1.7 on street tires or nitto drag radials.
Put another way, that's a round trip to 7-11 for a gallon of milk in under 3 mins if nobody is in front of me at the cash register
Just want to start off with a roll out of the hole and go through 3 gears, idle through the trap in 4th and take some data. Change the tune, rinse and repeat. Original concern was roll bar needed because of the mods, not the ET.
Probably going to check out Island this weekend but their website shows they are hurting for business. The place was a dump back in the 90s and I can only imagine the condition of it now..
Thanks for everyone's advice....well almost everyone
It's all good man, I'm from Jersey and believe in put up or shut up.
ive just gone through the frustration of thinking xxx and xxx parts are gonna make my car this fast... only to be beat down by the reality of the track. there is only one way to know how fast your car is gonna go. you can speculate all day but in the end you are right its put up or shut up. id love to be proven wrong. would love to get my car in the 9s. so i hope you keep this thread going with your results/findings. and remember there are drag tracks all over... you get kicked out of one you can always go to another lol
My thinking these days is focus the power on top and avoid the problems and costs associated with low end torque. Centrifugal on 13psi with a Blower cam rather than a PD blower. Leave on 350ft/lb and not 500 and bring that in 60ft later. Wheels up are for kids IMO unless you are a dedicated drag racer.
I'll post some updates on the build and should start dialing everything in next spring.
Suprfly (09-15-2016)
Received 1,576 Likes
First, they get pissed at Island when you go "too fast" and will immediately warn or yell at you when you get your timeslip. Usually a warning first, if you play dumb. If you go too fast a second time, you will either be told to go to tech or you will be asked to leave. Ask me how I know That being said, with the mods you have, you should be able to go low 10's there without issue on a cool day in the 60's or high 50's as long as you can hook up. I'm sure high 9's is possible but will be more difficult since you can't "practice" there. My C5 with the same mods went 10.8's @130mph a few times on two separate occasions where I stretched the limits. I don't have a cage and probably will never install one. I know it is for safety reasons but if you race a lot, you get use to the power and it doesn't even feel "that fast" after a while. Plus, you have to tear up the interior and I don't really want to do that, so I figure it's just easier to slow down and try and drive "normal" instead. Good luck and please post how well you do, if you go.
Btw, let me know if you're interested in drag tires/wheels. I may sell my setup.
