Any C5/C6 guys made a pass without the serpentine belt?
Has anyone running an EWP tried this on a max effort pass? Can you even do it without the ECU freaking out because of no alternator voltage output?
blkscls1z (10-13-2016)
Surprising results!
The basis behind my question is whether to run the ATI UD pulley or the IW pulley on my LS7. The IW pulley is over a pound lighter than the ATI UD pulley. With the minimal results you saw from no belt, the IW would be the clear choice.
my c5z runs without and I dont see any issues with the pcm on the aspect of no belt no alternator.. Although I do have stand alone wiring and also Deleted the bcm So if you have a BCM then that could do something but not sure if BCM controls anything that could reduce WOT performance...
