c5 rear gears
c5 rear gears
Does anybody know if there are rear end gears lower than 4:10 and who makes them? I've been thinking about doing some drag racing with a c5 and the local tracks are 1/8 mile. I will be using 26-28" tires with an ls1/a4 combo to start with. If I stick with it I will probably build the car to around 500 hp. Time will be limited as I also autocross a c5z and don't want to give that up. Thanks, Gary.
BIGMAC
I'm not sure that you will need gears lower than 4.10 for what you are doing but they are not available for a C5 or C6 diff. If you want to go lower you will need to go to a 9" center section.
