Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Friday is 406 Dyno day
Old 03-04-2017, 08:48 PM
moenoyze
moenoyze's Avatar
Default Friday is 406 Dyno day
After 3 weeks of waiting time has come to learn how much power my 406 makes. With 11.2 compression, air flow 210 heads, crane solid roller, holley strip dominator and 850 HP holley. I live 3 miles from ray barton race engines it made sense to go here. He has modern & up to date equiptment & talented operators. 10:00 am Friday we are ready to begin. On initial start up had a miss, I used my infrared thermometer to determine that #8 header was cold, found new auto-lite plug defective. Restart now hitting on all 8. Made a 5000 rpm pull, O2 sensors show way lean at 13.81. Rejet to #86 jets with 36 deg. timing resulted in 549 hp @ 6300 rpm. & 526 ft lbs torque at 5000 rpm. Moved timing to 40 deg. got a big surprise, 24 hp gain. 573 hp @ 6300 & 533 ft lbs of torque. With over 500 ft lbs of torque from 4000 to 5800 I could rent this thing out to pull stumps !!!
Old 03-05-2017, 01:57 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Nice numbers. it would be fun to run our 406s down the track.
Quick Reply: Friday is 406 Dyno day
