327 vs 350 rods & pistons
Old 01-11-2009, 06:34 PM
Dave64
Dave64's Avatar
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
Default 327 vs 350 rods & pistons
OK, so probably a dumb-azz question: can one use 327 piston/rod combo in a 350, given same overbore? I am thinking there is a difference in pin location. Would appreciate good input only. Thanks.
Old 01-11-2009, 06:40 PM
BLOCKMAN
BLOCKMAN's Avatar
Yep you aswered your own question
Old 01-11-2009, 07:58 PM
Dave64
Dave64's Avatar
Thanks Blockman.
Old 01-11-2009, 09:46 PM
cardo0
cardo0's Avatar
Location: Las Vegas - Just stop perpetuating myths please.
Default The sky is the limit on sb chevy parts swapping.
Sounds like u could use a small block chevy interchange manual to keep you out of trouble. I have one by Ed Staffel but there maybe more up to date books out now. Items like piston compressed height become very important when changing piston and rod combination s and when changing block deck height too.
Chevy made a lot of good performance parts that can be found used at pocket change prices. But u have to know which part will work for your combo.
Good luck,
cardo0
Old 01-12-2009, 10:57 AM
Dave64
Dave64's Avatar
My brother is rebuilding a worn-out 350 and I have several sets of 327 rod/piston sets in the attic. I was just checking to see if I could slip him some money savers. Thanks for the info.
Dave
Old 02-11-2009, 07:23 AM
rodj
rodj's Avatar
The 327's before '68 have a small journal rod big end (2.00 ) and all 350's had the large journal (2.10) so the rods might not fit dependent apon their model year
Old 02-11-2009, 03:08 PM
Dave64
Dave64's Avatar
Thanks rodj, I had a set of large journal rods & pistons. He got a great deal on a set of Crowers so now he doesn't have a problem.
Dave
To 327 vs 350 rods & pistons
Quick Reply: 327 vs 350 rods & pistons
