Largest stroke in a ZZ4 short block?
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
When I am college, 2 years, I wanna go for more cubes. I have a ZZ4 short block in now and am wondering whats the largest stroke and bore I can go with.
Received 1,400 Likes
Re: Largest stroke in a ZZ4 short block? (vettes rule)
go for a 396 or a 383
383: 3.75" crank and 4.030 bore
396: 3.875" crank and 4.030 bore
St. Jude Donor '13
Re: Largest stroke in a ZZ4 short block? (vader86)
What mods are required to the block to go with either the 383 or the 396? More specifically the clearancing for the longer stroke?
Thanks,
Vic
Thanks,
Vic
Re: Largest stroke in a ZZ4 short block? (89'Bowtie)
My engine builder had to grind away on the block to make clearance for the connector rods. It is just a trial and error thing. You need to figure out where to grind, grind a bit, then try to fit the crank/rod/piston in and see if it clears. If it doesn't you grind some more.
You can build your engine for as much horsepower as your checkbook can handle.
Cruise-In V Veteran
Re: Largest stroke in a ZZ4 short block? (Bob86ZZ4)
Thanks guys. I think when I get the $$$, I will go with a 396.
