ZZ4 run-on...
Old 03-20-2010, 03:14 PM
4S FED
4S FED's Avatar
Default ZZ4 run-on...
Hello all,
I have a 1967 with a ZZ4 crate engine. I'm having a run-on (dieseling) problem. I was wondering if any of you had any ideas of how to stop it.
Here's what I have installed:
ZZ4 350ci GMPP crate engine
Demon carb (crate engine model)
MSD 6AL ignition box
MSD Pro Billet Distributor (tach-drive)
MSD Baster 2 coil
Stock GM (2 wire) distributor
Stock(ish) ignition relay box
I've installed the little capacitor supplied with the 6AL box. I went back and double checked that it was installed correctly (soldered in-line on the green wire (4th pin on the ignition box), and that the line on the cap was closer to the plug going to the alternator). ... This didn't solve the problem.
My timing is set to dead-nutz "0"... should I advance it and see if that helps?
The carb is running a little rich, but all the floats seem to be set properly and the car runs fine....
Any help or suggestions would be great.
Old 03-20-2010, 09:01 PM
4S FED
4S FED's Avatar
Nobody???
Old 03-20-2010, 10:20 PM
warriorp
warriorp's Avatar
less timing and better octane fuel are your typical cures provided there is not a problem with vacuum leaks, carb poorly tuned, etc.
warriorp
warriorp's Avatar
how much total advace are you running on your distributor?
Old 03-21-2010, 12:25 AM
4S FED
4S FED's Avatar
The distributor is set on the spring they put in at the factory. They said in the manual it was best for most applications.... I'll have to look and see what color it is.
Old 03-21-2010, 12:26 AM
4S FED
4S FED's Avatar
I'm using Sunoco 93 and have put through several tanks.
Old 03-21-2010, 10:38 AM
warriorp
warriorp's Avatar
double check tdc on the balancer...the outer ring can slip and cause some major headaches...also try a dial back to zero timing light...set on 32deg total advance...remove vacuum advance hose bring engine up to full advance (typically 3500rpm) and line up timing marks...good luck!
Old 03-24-2010, 01:46 PM
08 Crystal Red
08 Crystal Red's Avatar
Some others things that might come into play---
Fast idle
Overheating
Carbon deposits
Hope it all gets worked out!
Old 03-24-2010, 03:59 PM
4S FED
4S FED's Avatar
Checked the timing and it was 3deg retarded. :o So, I went in steps, upping the timing until maximum vacuum was gained (about 15 inches at idle). Ended up with just a little over 9deg of advanced timing. Runs fine now (quite a bit more power too! )
Old 03-24-2010, 05:17 PM
08 Crystal Red
I'm glad to hear that -- since my ZZ4 is due in about two weeks!
To ZZ4 run-on...
Quick Reply: ZZ4 run-on...
