ls motor mounts, both sides the same?
i am working on an ls2 swap and it has the pedestal motor mounts , i think like in the 97-04 corvette. with 3 holes and the pedestal is offset.
my question is, can the mounts be swapped from one side to the other to offset the motor either forward or backward in the chassis?
i have the motor set in and it sits too far forward. if i could swap the mounts i think it would fix the problem.
