Beehive Springs in Double Hump Heads
Old 05-03-2014, 07:23 PM
H.O.Rider
H.O.Rider's Avatar
Default Beehive Springs in Double Hump Heads
I was considering installing a different cam in my 327 that would require a double spring. Comp recommended their 26918 beehive as a substitute instead of cutting spring pockets. Their site says 1.310 outside diameter at the bottom of the spring. My heads measure about 1.290 across the pocket...
Anyone use these in stock spring pocket double hump heads?
Quick Reply: Beehive Springs in Double Hump Heads
