Who sells a stroker short block for LS9?
Old 09-14-2014, 09:00 PM
Morphin
Morphin's Avatar
Default Who sells a stroker short block for LS9?
I havent found many options:
1. LPE 417 short block - $10,250.00
2. Katech 416 short block - $14,400.00
418 LS9 rotating assembly from Texas Speed is $3800.00 and a brand new LS9 block is $3300 but I dont know how much I will spend on having it machined, assembled and balanced.
Any other options out there?
Old 09-16-2014, 12:20 PM
mr.beachcomber
mr.beachcomber's Avatar
I'm not aware of any stroker LS9 assembles other than the ones you quoted. Given the options you mentioned, for my money, I would go with either the LPE 417 short block; or buy the components from Texas Speed and let them do the machining/assembly. If you invest that much money for a stroker, be sure to have someone assembly it that knows what they're doing. I have confidence in both of these shops to build a reliable stroker short block that can make big HP power and stay together in one piece. (Nothing worse that trashing a new engine on the first dyno tuning run!)
If you want a stroker, but not necessarily an LS9 block, I'd check out Scoggins-Dickey's 440 ci LS7 block "El Toro Grande". I've dealt with them for years and never been disappointed.
Good luck building your stroker!
Old 10-24-2014, 01:28 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
On the build get a shop that has a ton of time behind them doing it. To the OP here good luck with her...Robert
To Who sells a stroker short block for LS9?
Quick Reply: Who sells a stroker short block for LS9?
