Dart LS Next billit block
Old 05-14-2015, 02:33 AM
jcb5565
jcb5565's Avatar
Originally Posted by Trackman101
Are you going to be using a hydraulic roller cam? Which oil pump did you choose? Will you be using oil restrictors?
I will be using a special grind comp cam with the short hydraulic roller lifters. The oil pump is a melling stock oil pump with the lighter spring. The high performance oil pumps will give you to much oil pressure in the Dart LS Next Block. That one of the great future of this block over the LS series Chevy block. Oil restrictors only needed on solid lifter set up. Got the crank installed today, that crank turns with little effort
Old 05-22-2015, 05:35 PM
jcb5565
jcb5565's Avatar
Tackman here is the parts number for the Melling oil pump. Use the 10295 and install the optional blue spring supplier with the pump.
Old 05-22-2015, 07:37 PM
Trackman101
Trackman101's Avatar
Thanks, it's bolted up ready to go!
Old 06-05-2015, 01:48 PM
jcb5565
jcb5565's Avatar
Trackman did you find a solution to the AC mount problem? I guess a little mods will be needed.
Old 06-05-2015, 02:46 PM
Trackman101
Dart "just" completed a revised pan rail. There is not even a part number yet. I ordered mine this morning. I would contact them direct.
Old 06-05-2015, 11:06 PM
jcb5565
jcb5565's Avatar
This the rail adaptor I have dose your look like this.
Old 06-05-2015, 11:18 PM
Trackman101
Yes that rail is the same. It's the other rail that they have revised.
Old 06-06-2015, 12:52 AM
jcb5565
jcb5565's Avatar
The one your are looking at is the passenger side. The bracket holes are for the ac.
Old 06-23-2015, 10:19 PM
Trackman101
Hmm, my factory lifter valley cover does not fit.
Dart is making this real difficult to make this a street motor.
Old 06-25-2015, 08:24 PM
Trackman101
Need to design custom alternator mount now.
Old 06-26-2015, 12:31 PM
jcb5565
jcb5565's Avatar
You will need the LSX cover.
Old 09-15-2015, 10:55 AM
Trackman101
jcb5565, Any updates on your Dart LS build?
Old 02-14-2016, 11:14 AM
  #33
Trackman101
These pan spacers are a joke.
Quick Reply: Dart LS Next billit block
