7115 crank thrust washer
Old 01-29-2015, 09:28 PM
chrislyn
chrislyn's Avatar
Default 7115 crank thrust washer
I have a 7115 crank that has a crack in the thrust washer. Can this be welded and then machined.
Old 02-05-2015, 08:49 AM
mr.beachcomber
mr.beachcomber's Avatar
These high performance 427 cranks were forged so if you have a crack in the face of the thrust washer surface, merely welding and re-grinding the surface flaw isn't going to remove the internal grain flaw that started the crack to begin with.
If you do this, don't wail on the engine. You might be able to drive it around town, but don't subject the engine to a lot of high RPM/high load driving. The internal flaw will show up in a new location. Worst case is that the internal flaw extends to a journal that breaks under heavy load.
Given the availability of really good aftermarket forged crankshafts, I'd replace the unit personally. YMMV. Good luck!
Quick Reply: 7115 crank thrust washer
