help choose carbs for 434
I am considering dumping efi for carbs for a couple reasons. The motor on a stand is like 700hp. Been on chassis dyno bad efi tune and shutting itself off at 5K made like 500rwhp and tq roughly. Rev limiter 7K.
I currently have a Motown single plane on the car and would like to know what size carb to use on that if I stayed with it.
The next option is I want a tunnel ram so what size carbs for that one?
434
AFR 220 comp port heads
Howards cam 248-256 @50 110LCA .650 lift
Howards 1.6 rr's
3.45 gears / auto
10.8-11 comp
434
Howards 1.6 rr's
3.45 gears / auto
10.8-11 comp
I would try a 800 CFM DP on the Motown
for the tunnel ram
https://www.holley.com/products/fuel...s/parts/0-4224
for the tunnel ram
It's not recommended to take a 400gm block to 434 has been done though. Dart Aftermarket block.
http://shop.whiteperformance.com/SBC...D-DRTBLOCK.htm
