Wet sump vs dry sump
I'm pretty new around here but already know this forum is the best place to get answers. I'm getting started restomoding a junked out '67. The LS7 is ordered, but I noticed the engine was converted from dry sump to wet sump. What's the difference and why does everybody seem to make this conversion? Thanks.
That works fine as long as there is enough oil in the pan for the pump to suck. Really sharp curves and turns can cause the oil to slosh to the side, not get sucked up, and allow the bearings to get damaged due to lack of oil.
A dry sump system stores the oil in a separate canister. It sucks the oil from underneath the engine much more aggressively. Usually they include and air/oil separator in the system. This in important because the oil takes on air as it is whipped around in the engine. Oil foam does not lubricate engines well. This system better manages the oil in high G, high rpm situations. It also allows the engine to make more power.
Folks do not use the dry sump system because it takes fitting and plumbing another tank with extra parts. It is also much more costly than a wet sump oil system.
6th Gear
Wet Sump vs Dry Sump
Engineering Explained produced a pretty good video about this recently:
