Modeling a 406 street engine w/DD2000 Is this Right?!?
Hi guys,
Just playing around with Dyno2000 for a SBC400 build up. These numbers seem too big for some reason. Here's what I put in...
SBC 400 .30 over
AFR 190 heads
9.5 compression
750 cfm carb
small tube headers w/mufflers
For the cam I chose a Crane hyd roller #119831 with the following specs...
http://www.cranecams.com/master/apps...#3.%20PowerMax
Here's the hp / torque graph...
Questions
How realistic are these numbers?
How streetable is this cam?
Should I sacrafice torque for more hp up top?
Any recommendations?
With a SBC400, is additional machine work needed for 6in rods?
Car will be a weekend cruiser. Automatic trans with 3.36 gears. I don't want to give up any drivability (ie. Poor idle or low vacuum). I'm leaning toward a hyd cam for just these reasons, you can get a more agressive grind w/ less drawbacks (I think).
Any feedback appreciated...
--Jack
SBC 400 .30 over
AFR 190 heads
9.5 compression
750 cfm carb
Questions
--Jack
Re: Modeling a 406 street engine w/DD2000 Is this Right?!? (74jack)
That seems very realistic. That cam is streetable on a 350 it would be much more streetable on a 400, that's why you have so much bottom end. I would run about 8deg more of intake duration and exhaust you'd still have about 500ftlbs a little higher and about 450 horse use a small single plane like a victor jr it gives up no low-end when compared to a dual plane and gives more top end. Anyway this is a good combo should be good for at least low 12's.
Re: Modeling a 406 street engine w/DD2000 Is this Right?!? (JUAN J SANCHEZ)
Well, did you select roller cam from the menu? If so, set it to flat tappet (the manual also mentions that), the roller cam selection is only for true race rollers w/ very aggressive lobe profiles.
Marck
Marck
119831?? I am just guessing, but is that cam also recremmonded for Forced inducted engines? I am guessing that cause I thought that their numbers 119831, 119841, 119851 were their 3 cams designed for forced induction. I could be wrong though, and I have not gone to look to answer my own question either.
