What's the difference: Stud girdle, rev kit, rocker shaft system.
Newbie question:
Can you please explain the difference of a stud girdle, hydra rev kit, crower shaftrockers and the jesel rocker shaft system.
Thank you.
[Modified by Hammer, 3:24 PM 3/13/2003]
Thank you.
Re: What's the difference: Stud girdle, rev kit, rocker shaft system. (Hammer)
Without going into great detail about each here is general info.
Stud Girdle - pretty much how it sounds, it helps keep the rocker studs from moving or flexing
Hydra Rev kit - for use with hydraulic lifter, it applies spring pressure to the lifter body to allow for the use of a weaker valve spring and help prevet lifter collapse at higher rpms http://www.airflowresearch.com/pages/hydra_rev.htm
Shaft rocker - This completly replaces you current rockers and studs with a rocker shaft the rides through the center of the rocker. Good for high rpm applcations, solid rollers
Hope this helps
Hope this helps
