silly big block question
Old 08-02-2004, 03:10 PM
hubes
hubes's Avatar
Default silly big block question
what is the crankshaft to camshaft height on a standard big block? I tried searching the internet but can't find it, thanks
Old 08-02-2004, 09:27 PM
The Green Rocket
The Green Rocket's Avatar
Check with the aftermarket block companies like Dart, Brodix, etc. In the case where they list raised cam blocks I imagine they will list more technical specs that could help you with this dimension.
I would expect that a competent engine machine shop would have this dimension.
Thomas
Quick Reply: silly big block question
