F-Body General Discussion Non-Corvette General Discussion on Camaro, Firebird and Trans Am, F-Body Technical Info, for sale
Is this cheap z28 worth getting?
Old 08-13-2014, 04:07 PM
corvettesforevor
corvettesforevor's Avatar
Default Is this cheap z28 worth getting?
http://appleton.craigslist.org/cto/4614846214.html
There is a 1994 z28 on craigslist for 2000. It is in fair condition, paint is pretty good, interior is a little rough. It needs a new windshield because it is cracked. The guy also tells me the transmission leaks and slips into gear, "but it just needs a new sensor" Would a bad sensor really be causing leaking and slipping?
I said I would consider doing 1600$ for it. He said he would take it. If It is really just a sensor that needs replacing that wouldn't be hard to fix. But would a bad sensor really be causing those problems? I could buy a windshield and replace the sensor and have a decent and fun car for less than $2000. But the transmission sounds worse than just a sensor to me. He tells me the tranny was also rebuilt last year.
Is this worth getting into? Or does it sound like more problems then he's letting on to?
corvettesforevor is offline
Old 08-13-2014, 07:51 PM
kcust62
kcust62's Avatar
Doesn't look to bad in the photos...KBB price at $1600 is right on. If you're a do-it-yourselfer and want a project, I'd say go for it. You won't know what sensor he is referring to until you connect a diagnostic tool and download fault codes. As far as a "sensor" causing the tranny leak, I've never heard anything so ridiculous in my life, unless the oil is running through a damaged sensor itself.
kcust62 is offline
Old 08-13-2014, 09:26 PM
jim2527
jim2527's Avatar
Assume it needs a new/rebuild transmission and go from there...
jim2527 is offline
Old 08-14-2014, 01:47 PM
leadfoot4
leadfoot4's Avatar
Received 1,346 Likes on 1,097 Posts
Originally Posted by kcust62
... As far as a "sensor" causing the tranny leak, I've never heard anything so ridiculous in my life, unless the oil is running through a damaged sensor itself.
But there are a couple of "plugs" for the computer, that go into the tranny case.
leadfoot4 is offline
To Is this cheap z28 worth getting?
Quick Reply: Is this cheap z28 worth getting?
