East Coast Supercharging 4L6X Trans W/Yank PY3400 Converter *NEEDS 3/4 CLUTCHPACK*
ECS 4L6X Transmission with Yank PY3400 Converter, needs a 3-4 clutch pack. has 2,xxx miles, was never overheated. fluid is bright red and unburnt, instead of rebuilding again i'm going 4L80, i was running the WannaGOfast half mile event in florida this past january and had to pedal the car at over 100mph because of wheelspin which caused the 3/4 clutch pack to let go. car was then loaded into the trailer and dropped off at East Coast Supercharging where they pulled the trans. it has all the good stuff in it. and is capable of holding 700+ whp it was in my F1A-94 procharged Trans Am making 19# boost and worked great until a dusty and cold runway surface caused intense wheelspin and the clutch pack let go. heres a list of whats in it. East coast supercharging can verify everything.
ECS Race 4L6xE Build - Blueprinted 13 Vane Trans Pump with hardened rings & rotor, Input Shaft, Billet Apply Pistons, ECS Custom 3 / 4 Clutch Pack, New Reverse Input Drum, Extra Wide Carbon Band, HD 29 Element Input Sprag, HD Low Roller Clutch, Billet 2nd Gear Servo, Billet Pin-Less Accumulator Pistons, 5 Pinion Planetary Sets, New Solenoids, Shot Peened Output Shaft, Updated Spacer Plate, ECS Prepped Valve Body with HD 2 / 3 Valve Modification, New Bearings/Seals/Gasket
PATC-Smart Tech Input drum
$1,000 includes Converter and can ship at buyers expense. Transmission is at East Coast Supercharging in New Jersey.
