F-Body General Discussion Non-Corvette General Discussion on Camaro, Firebird and Trans Am, F-Body Technical Info, for sale
F.S LS Swapped 1991 Z28
Old 09-09-2016, 03:47 PM
combatdoc
combatdoc's Avatar
Default F.S LS Swapped 1991 Z28
1991 Z28
LS6, fresh motor has approximately 2000 miles on it now, from 04 Z06
stage 2.5 241 heads, milled .040, 2.05 exhaust valves, trunion upgrade brand new PEC .650 springs w/titanium retainers, new 7.425 pushrods,
torquer V2 cam (232/235 .600/.600), LS7 lifters. Fast 92 intake/92mm CT TB, GTO CAI, HEADMAN mid-length swap headers (coated), LS2 coils, MSD wires. All new hardened motor mounts. Dynomax crossflow muffler with mandrel bent 3in. exit pipes, cut to resemble stock only bigger, tucked away just as stock pipes.
Tranny is T56 from 2001 TA, has approximately 60,000 miles on it, LS7 clutch, new PRO 5.0 shifter, TIC clutch MC
Rear end is 2002 camaro SS with 3.73 and disk brakes. Upgraded Mouser cover, hardened adjustable panhard rod, control arm, front frame brace, strut brace, frame connectors, all new KYB shocks.
Front brakes are C5 Z06 with drilled rotors, steel braided lines, (bigbrake.com) Wheels are TSW Snetterton's 18x8 front 18x10 rear, 255/40/18 front 285/35/18 rear Just put new rear tires on 200 miles ago.
Fuel pump is 255 warlbro in stock tank, used early C5 filter/regulator
Interior is stock besides 2001 TA leather seats, fully electric and lumbar/bolster support all work, dash has no cracks, all stock gauges work perfectly, new heater core. 82,xxx miles on car. T-Tops, AC works great.
Hood of car was recently repainted due to chipping, whole car was sanded and re-cleared also. Car still has original spare with can in trunk area, T-Top bag also.
Car put down 436WHP and 389WTQ after Henderson Performance tune
gets great fuel mileage on highway and drives very smooth for a 90"s sports car.
The Bad, headliner is starting to do the separation act, could have that fixed shortly, small chip on hood from a rock truck on 190, this is being fixed soon. Small stain under passenger floor mat form dex-cool (heater core leak), have been spraying and shampooing the stain every few weeks it has gotten a lot lighter. Car is not perfect but Dave (fullyvetted) has seen the car and knows how picky I am.
Price on car is 16,000 OBO, I do have the title. any questions PM me and I will get back with you ASAP. I may have missed something on here, if so I will add or answer as it come up. Car runs very well and sparks conversation everywhere. Any questions please PM, I am located in central Texas, thanks Dan PRICE DROP 15,000 FIRM
combatdoc is offline
Old 09-11-2016, 04:45 PM
TD-Machines
TD-Machines's Avatar
Nice, if I wasn't so fixated on getting a old Mopar I would consider this.
Good luck with the sale.
TD-Machines is offline
Old 09-20-2016, 06:59 AM
kg4fku
kg4fku's Avatar
That is one nice car!
I can only imagine this thing is just stupid fast with the same power of a current gen but about 500lbs less weight. Has it been to the track?
Too many IF's in my life right now or I would be at your doorstep with cash.
GLWS! Someone is going to get one awesome car.
kg4fku is offline
Old 09-21-2016, 08:05 PM
combatdoc
combatdoc's Avatar
Thanks, have not been to the track with new motor, old motor ran 11's and trapped at 117-121, with hoosiers, I'm sure a guy that is alittle quicker with shifts an rapes it off the line could do alittle better. I like highway pulls in mexico, car runs very nice up top for small cubes. I dropped the price to 15, surprised nobody has hit on it. Chip on hood is being fixed as we speak also. If it does not sell I will be running 1/2 mile drags with it. I will see whats she's all about there, I figure 140-145.
Old 06-13-2017, 05:52 PM
'Shifter
Thoroughly chapped
Support Corvetteforum!
'Shifter's Avatar
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Nice ride....
'Shifter is offline
To F.S LS Swapped 1991 Z28
Quick Reply: F.S LS Swapped 1991 Z28
