Ground straps
Ground straps
Can anyone tell me the # and location of the ground straps on a small block with air coupe. Or would onr of the ground strap kits have the location?
Thanks,
Tom McCabe
Thanks,
Tom McCabe
Re: Ground straps (sting66ray)
For the 69, you would have a flat copper strip at the radio antenna ground plane, two flat braided copper cables at the exhaust clamps on the forward exhaust support, one flat braided copper cable at the birdcage sill near the driver side #1? body mount, and a rubber covered copper cable from inside the right frame motor support to the engine block.
Now, if you are asking about the 66, I haven't a clue. :jester Oops, the 66 is gone.
[Modified by Chuck Sangerhausen, 6:21 PM 8/29/2001]
Re: Ground straps (Chuck Sangerhausen)
Sorry guys this is for the '69, I removed a ground strap for the A/C off the radiator support, but don't see it in the AIM, does anyone else have an A/C Car?
Thanks Tom
Thanks Tom
