Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
J-56 casting numbers
Old 12-29-2001, 07:46 PM
BAD-L88
BAD-L88's Avatar
Default J-56 casting numbers
Hi,
I was wondering if anyone could tell me the correct casting numbers for J-56 front calipers?
I have come across someone with several "2 pin" calipers but some of them may be converted from single pin. I need to verify what is what by the casting numbers.
Thanks,
B-L88
[Modified by BAD-L88, 3:47 PM 12/29/2001]
Old 12-30-2001, 02:39 PM
Brass
Brass's Avatar
Default Re: J-56 casting numbers (BAD-L88)
I just looked on the set lying in the trunk of my car, which are from my early 66. The casting number is 5465952.
Hope this helps.
Old 12-31-2001, 12:31 PM
BAD-L88
BAD-L88's Avatar
Default Re: J-56 casting numbers (Brass)
thanks Brass,
Very interesting. I am getting different numbers from the C3 board. Rowdy Rat states that the numbers are the same as standard. Now, I wonder if the difference is in the year of the parts?
B-L88
Old 01-01-2002, 06:28 AM
Brass
Brass's Avatar
Could be. Want photos?
Old 01-01-2002, 01:02 PM
JmpnJckFlsh
JmpnJckFlsh's Avatar
Jay, looks like its going to be more complicated than that.
According to the parts book I have, there are unique part numbers for "heavy-duty" caliper housings for front, rear, RH, LH, inner and outer. It appears that there are also different part numbers for "heavy-duty" caliper housings for 65-66, 67, and 68-72. Unfortunately, this parts book does not give casting numbers, and the part numbers are useless for your purpose.
I have no experience with J56 calipers, but I assume that "heavy duty brakes" implies J56 calipers.
Old 01-01-2002, 01:23 PM
Rowdy Rat
Rowdy Rat's Avatar
Default Re: J-56 casting numbers (Chuck Sangerhausen)
Chuck,
There were three distinct sets of caliper housings. The original calipers were supplied by Delco Moraine and are identified as such on the casting. The casting numbers are as follows:
1965-Early 1967
5465954 (front, inner)
5465952 (front, outer)
5465902 (rear. inner)
5465905 (rear, outer)
Late 1967-Early 1972
5452270 (front, inner)
5452273 (front, outer)
5452281 (rear, inner)
5452284 (rear, outer)
Late 1972-1982
5473795 (front, inner)
5473796 (front, outer)
5473806 (rear, inner)
5473807 (rear, outer)
The casting numbers are the same for both standard and J-56 brake calipers (the housings themselves) within the date ranges given... The part numbers are different because the caliper castings are machined differently.
There is additional information and photos posted over in the C3 forum.
Regards,
Old 08-17-2016, 03:12 PM
vetteheadracer
vetteheadracer's Avatar
2022 C7 of the Year Finalist - Unmodified
Originally Posted by Rowdy Rat
Chuck,
1965-Early 1967
Late 1972-1982
Regards,
My 1965 Corvette SCCA Race car has a mix of J56 brake casting numbers!
To J-56 casting numbers
Quick Reply: J-56 casting numbers
