Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
1969 clock knob stem
Old 08-05-2008, 08:30 PM
400hp427vette
400hp427vette's Avatar
St. Jude Donor '09
Default 1969 clock **** stem
my clock stem is broken where the **** threads on, Anyone know where to purchase the proper clock stem.
Old 08-06-2008, 07:17 AM
corvetteload
corvetteload's Avatar
Buy a Hemmings Motor News, under "services" there is a myriad of places that restore clocks and instruments, grab your phone and start calling and you might get lucky!!!
Or watch ebay and buy every clock for the next year that pops up and maybe you can get a good shaft without bitching things up...........good luck
Old 08-06-2008, 09:39 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
http://www.corvetteclocks.com/
I've also seen the stems listed with some of the Corvette aftermarket providers.
Old 08-06-2008, 12:58 PM
JohnZ
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
You'll need more than a stem. If the stem came off, something is sheared in the works, and the clock needs to come out for repair/rebuild. The Clock Works (www.clockwks.com) does excellent work with quick turnaround.
Old 08-06-2008, 07:52 PM
400hp427vette
St. Jude Donor '09
I should say the stem tip broke off at the threads where the **** would screw on
Old 08-06-2008, 10:24 PM
gbvette62
gbvette62's Avatar
Received 2,016 Likes on 1,308 Posts
One of the gauge restorers may be able to fix it (but be prepared to be without it for a month). Try any of the following.
1)Clocks by Roger in Tenn
2)Corvette Gauge Service, Palm Beach (?) Fla
3)Corvette Speciaties of MD
I know Roger and Corvette Speciaties will be at Carlisle and maybe Corvette Gauge, if you can wait.
Complete repro clocks are available in either mechanical or quartz movment. These run about $150,00. You can by a quartz movement to convert your clock yourself for about $60.00-70.00, but I don't remember if they reuse the old stem or not. This may be a more cost effective way to go.
Just curious, was that originally a no radio car, or did you convert. I like it either way!
Old 08-08-2008, 12:54 PM
Easy Mike
Easy Mike's Avatar
Same thing on my '68. Clock was otherwise fine. I replaced the stem.
To 1969 clock knob stem
Quick Reply: 1969 clock knob stem
