Great Lakes Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin
Re: Low beam failure linked to faulty fuse box...
Old 07-23-2014, 07:11 PM
Tom_Slick
Tom_Slick's Avatar
Default Re: Low beam failure linked to faulty fuse box...
Nerver mind...
Old 08-04-2014, 01:31 PM
johnsos30
johnsos30's Avatar
I'm having a headlight issue as well. Driver side comes up won't turn on. Good ground and fuses. What did you find?
Old 08-06-2014, 09:12 PM
Tom_Slick
Tom_Slick's Avatar
There is a known issue… And according to a very reliable source, GM is aware of the problem(intermitten failure of the low beams, linked to a wire shortage in the fuse box when it warms up/ swells causing a temporary short, and once cooled the lights working again.) There was supposedly a recall issued in May. The only problem is local dealers may only have the old stock vs the new and improved stock… So getting a "old stock" fuse box will be a temporary fix until the new boxes become available in late September… In another forum thread on the subject some forum members have gotten letters stating something like, "We are aware of the problem and are working to correct it… You will get a second letter from GM once the part is in stock and available to repair your vehicle…"
Old 12-17-2014, 07:03 PM
Tom_Slick
Tom_Slick's Avatar
Finally got the car in and fixed today… Whew, what a relief.
Old 01-05-2015, 08:45 PM
Tom_Slick
Tom_Slick's Avatar
My recall letter came in the mail today… Stay classy G.M.
To Re: Low beam failure linked to faulty fuse box...
Quick Reply: Re: Low beam failure linked to faulty fuse box...
