Great Lakes Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin
TPS C5 C6 Tunnel Plate w/ Thermal Heat Shield-$259 Shipped!
Old 09-18-2014, 08:31 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Default TPS C5 C6 Tunnel Plate w/ Thermal Heat Shield-$259 Shipped!
-1/4" Thick Aluminum
-Reduces in car temperatures,
-Eliminates creaks and chassis flex
-Over 2x as thick as your stock c6 or 4x the thickness of a C5 tunnel plate.
-Works for all C5 & C6 Corvettes
-Made in the good ole USA
Say good bye to HOT CONSOLES & TRANSMISSION TUNNELS!
Click here to place your order
So what is a tunnel plate?
*A tunnel plate is a plate which GM used as a barrier to separate the exhaust from the torque tube in a in C5 and C6. It was first introducted in a C5.
What does it do?
*GM initially intended for the plate to be used as a barrier for the exhaust from the torque tube underneath the car. For the C6 cars GM installed a thicker one as they discovered the plate also helped reduce chassis flex in addition to keeping out heat.
Why do I want the TPS Tunnel Plate?
*The TPS tunnel plate is over 2x as thick as the factory C6 Plate and 4x the stock C5 plate. Installing the TPS plate will help reduce in car tempertures because it provides a better heat barrier from the exhaust. It will also eliminate many creaks and chassis flex due to the increase thickness and rigidity of our plate.
How hard is it to install?
*With the factory mid-pipe removed it will take you less than 30 minuetes to install and can be done with simple hand tool! If your doing long tube headers this is a perfect upgrade to do at the same time.
Specs
The engineers at General Motors acknowledged the benefits of a stiffer more rigid Tunnel Reinforcement Plate and improved their original design and incorporated something similar into the new C6.
Z-Cool Thermal Heat Shield
With our option Z Cool Thermal shielding temperratures have been shown to decreas by 20-40 degrees!
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...
Quick Reply: TPS C5 C6 Tunnel Plate w/ Thermal Heat Shield-$259 Shipped!
