Chicago NW burbs garage heat recommendation
I'm looking to install a gas heater in my garage before winter. Was wondering if anybody here has any recommendations or referrals for companies you used before I start just cold calling for quotes. I'm located in Volo.
If you know anyone in the area, please let me know, thanks!
I had a modine hot dawg, it lasted 10 years, only used 4 months a year, clean environment and the expensive combination gas valve on it failed, it wasn't a good payback. Picked up a 80k btu Mr. Heater Big Maxx last year about this time for $400 out the door at Lowes. That was a sale price and 10% off for opening and putting on their store charge. Knock on wood good heater and quieter than the Modine. Spent a few more dollars on sheet metal to hook up to old exhaust and removed the flex line the prior owner had and hard piped it. Had to have a neighbor help me hang the unit, getting old, couldn't do on my own. Not sure if that will help you or not but it is what I spent.
Thanks, I may just come check that out.
I've gotten 3 quotes so far, ranging from $1700-$2200 installed for a 30k BTU unit. The cheap quote was for Modine, expensive was for Lenox. Gas and electric lines are no more than 10 ft from where I want it mounted.
I plan on having it run all winter to keep my garage temp around 50-55 consistently
Received 1,090 Likes
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Why stop at just heat???
I have a cousin into Vettes and Harleys. Insulated and drywalled his garage and added a Mitsubishi combo heater/ac. Ran about $3800 or so.
Warm in the winter, cool in the summer!!
I'm in an interior unit townhouse with 2 car attached (front and 1 side wall exposed) with a cheap overhead door. I have an electric heater rated a few btu more than required. The heater was around $500 and It costs about $50/month if I keep it around 50 degrees.
