Comp Cams dual valve springs (26925TS-KIT)
Location: I'm a living organ donor! Sporting one kidney since 2002!
Like new. Less than 1000 miles on them. Comes as pictured (does not come with valve stem seals). All that you will need will be new valve stem seals (Compp Cams part number 511-16) and you are good to go ($25-$30) Real world price on this kit is $420.
From Comp Cams:
This Dual Valve Spring Kit for LS engines includes carefully matched Dual Valve Springs, tool steel retainers, locks, seals and spring seats. With a .660" maximum lift, these COMP Cams® Dual Valve Springs for race applications are manufactured from Super Clean™ wire and subject to extensive quality control testing to deliver a valve spring assembly with superior strength, durability and valve train stability, no matter the application. The dual spring design creates a stronger valve spring that can easily handle the increased lift found in extreme stress applications. COMP Cams® Dual Valve Springs exceed the expectations of today’s engine builders and racers.
Yours for $300. I accept PayPal. Check my trader rating and buy with confidence.
Please feel free to call or text me at 708-254-8600.
Thanks,
Mitch
From Comp Cams:
Thanks,
Mitch
