Help Forum How To | General Corvetteforum Questions | Feedback
headlight operation
Old 07-16-2010, 10:54 PM
unworthy
4th Gear
unworthy's Avatar
Default headlight operation
I would appreciate some guidance.
When I turn the headlight switch to the "parking light" position, the headlights open but do not turn on (rather than waiting to open in the headlight position on the switch).
In the headlight "on" position all is correct.
When the lights are turned off, the passenger light door continues to attempt to shut for 7 seconds after being completely down, making a machine gun like noise before turning off.
Finally, I unplugged the passenger headlight and the drivers light works as it is supposed to, meaning, it comes up when the switch is in the "headlight position".
Where is my problem?
unworthy is offline
Old 07-16-2010, 11:57 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
You should post this in the correct forum. This HELP forum is for help with the forum itself.
If you had either filled out your profile or put in your post (above) what model year of Corvette you were asking about, I'd know where to tell you the correct forum was.
Vette_DD is offline
Quick Reply: headlight operation
