smart phone login
smart phone login
Why doesn't my current login and password password work on my cell phone when I enter a forum?
If your password and username are being rejected, then the only two possible reasons are 1)you are entering in the incorrect password/username combo or 2)you are using the incorrect CaSe sensitive password.
Passwords are CaSe sensitive. Perhaps you're not using capitalization (if you have a password that has capitalized characters), or you have the Caps lock on for your phone for a password that is all lower case.
If you're being logged out while browsing the forums, then you have a cookie issue with your browser. You'lll need to delete all CorvetteForum cookies. Logging out is not the same and will not work.
