Facebook login
I believe you should be able to do this by going to the UserCP: http://forums.corvetteforum.com/usercp.php and then entering in a new password and making sure you have a valid/normal (which appears you do) email address on account.
If not, let us know.
"The password you have entered does not match your current one. Please press the back button, enter the correct details and try again. Don't forget that the password is case sensitive. Forgotten your password? Click here!"
You're right as I thought of that after posting the reply.
I can either manually set a password on your account and PM you it (you have email notifications turned on for PMs so you'll get an email with the password), or you can use the Reset feature (Forgotten your password).
If you want me to set it, let me know. It'll go to your RR email account. Or you can PM a temporary password you want to have set on your account.
Then you can go through the instructions I posted above to give yourself whatever password you want.
Thanks for reply.. I tried to change pw, but it requires that I put current pw in before change??
One more q.. is there a way to turn this off permanently?
"Publish this to your Facebook Stream "
This was reason I wanted to change from using facebook login
