full message box?
full message box?
If a member has a full private message box, will the message I sent be able to be viewed when he clears the box or will I need to resend it? Thank You
If you was shown the error that the recipients inbox is full, then no the message would not be seen by the recipient regardless if the inbox was cleared or not. The message will need to be manually resent.
