Get new posts within one subforum only?
Any way to get a list of new posts in just one subforum? In my case, it would be great to get all of the new posts in the C5 forums without having to click through each individual C5 subforum every time I visit.
The "new post" button is great to browse a few pages of new stuff across the board, but this forum is so busy that I do miss a ton of stuff between visits. It would be nice if I could at least keep up with the C5-related stuff a bit easier.
Is there a direct link like http://www.corvetteforum.com/forums/....php?do=getnew (and then some sort of url extension to choose only a specific forum group)?
The problem will likely be that trying to add all those C5 forums will not fit in the 10 page restriction.
Otherwise, the link would be like this:
http://forums.corvetteforum.com/sear...&include=103,1 for C5 General and C5 Tech.
BTW, you will need to copy and paste this link your bookmark as you see it:
If you wait to bookmark the above link after you click on it, note that the link in your address bar will have change to a searchid and if you bookmark that URL then you're bookmarking a search that will expire.
Code:
http://forums.corvetteforum.com/search.php?do=getnew&include=103,1
Thanks, yeah I did notice that. I also figured out the ID's of all of the C5 forums, so my search now looks like this:
https://www.corvetteforum.com/forums...8,49,52,53,165
Just out of curiosity I changed it to "exclude", and made a search that shows all new posts across the board, except for the C5 forums:
So now I can read 10 concentrated pages of C5 stuff, and then 10 pages of everything else. It prevents the same threads showing up in both searches, too.
Thanks again
Thanks again
