can't reply with quote
I'm randomly having similar problems. Instead of listing the previous posters quote, I get a strange response. You can see it in this thread below in my post #5 where I am trying to quote post #4.
BTW, I used to be able to copy a single post but it doesn't look like that is available anymore? If I remember, I would click on the post number but it doesn't work now.
https://www.corvetteforum.com/forums...pstate-ny.html
I am using an Ipad with Safari, not mobile 7.01 I think, not the new 8 version
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
Same here JT
Some threads work, others do not, can;t use reply with quote or multi quote.
https://www.corvetteforum.com/forums...ur-ls9-45.html
This thread above doesn't work. Windows 7 on Firefox. Thx.....
I was able to quote your example post with Firefox as shown in the attachment. Additionally, when you click on the post number in the upper right corner, it should simply focus your browser on that post and it will change the URL in the address bar to reflect the focus feature. That feature was never used for quoting. If clicking on that post number does nothing, then you have a browser issue as it's simply a link - no fancy code and is not something specific to CorvetteForum.
I was able to quote in that thread and there are quotes on the second to last page to suggest it is working to atleast some degree. I'm also using the same setup (Windows 7 and Firefox as well as Windows 8 and Firefox) as you.
In order to better investigate, I'll need a specific post you can't quote rather than a thread as I can't really try to quote 45 pages worth or 883 posts from that thread.
Same here JT
Moderator
Events Coordinator
Moderator
Events Coordinator
OK, I see you used an attachment so that may explain why no pic, I also see there is a quick reply option off to the side now which must have replaced the old reply.....
I can quote #883 without issue.
When a post has an attachment using the old legacy attachment system, the attachments are shown below the post. Those won't appear in the quote. When a post has an attachment using the new attachment system, or other inline image, those will appear in quote. That's actually normal behavior for vBulletin software.
Maybe 882 is the problem, I can't reply with quote or multi quote it with 883. Is there a size limitation or something? I usually edit the pics out and keep the verbiage. Also the only option I am getting is reply with quote, not just reply on things. This I hit reply with quote and it didn't bring up the pic
Moderator
Events Coordinator
I already tried post 882 as shown in my reply above:
https://www.corvetteforum.com/forums...post1588139467
It still works today as shown in the attachment.
Like I said, if this is about some images appearing in the quote and some not, it's the way the member posts the images. Attaching images using the legacy feature, such as post 882, won't be quoted. Attaching images using the new attachment tool or hosted elsewhere and posted inline, such as post 883, will appear in quotes.
