Can not edit post
Can not edit post
I need to edit post # 3 in the 1/4 mile challenge sticky of the C6 tech section. I am trying to update the St Jude information.
When I try to edit I only get a blank box and a choice to delete or not ot delete the post.
Thank you
Tommy
Thank you
Tommy
There was a special character that appears to have been the cause of the issue. For now, I have removed that special character and so editing your post should now work regardless of the editor you have selected.
Also to note, you had a lot of extra code with some stacked on top. Such as two different colors assigned in a row or two different fonts assigned in a row. You can only use one color or font at a time. I cleaned up some of that extra code that did not do anything because it was stacked.
It worked, thank you
Tommy
