Archiving PMs
Archiving PMs
I am constantly at or near the limit of my PMs and I have already had to delete some I would have liked to have kept. How can I save them to my laptop or otherwise transfer them from the forum to my own email or drive?
Have you actually done this? I got three messages telling me the photo software is no longer supported or something to that effect.
Yes, I have actually done this. It is a native feature to the software. And trying it again, just now, works normally as this screen capture shows. You get a dialog prompt to save the file.
Photo software has nothing to do with this feature.
In order to assist, we need to know the exact error and the exact issue.
On my computer it tries to create a php file extension with no option to change. php is PhotoParade.
When you click on any of the 3 links (XML, CSV, TEXT)? Or when you try to open after saving from one of those formats?
Clicking on the XML will save the file as an XML document, clicking on the CSV will save the file as a CSV format and TEXT will save as a Text.
If it happens when trying to open after saving, which one are you picking?
Regarding the PHP is PhotoParade, that's an association issue with your computer. Apparently, you either installed PhotoParade or it came with your computer and it's set to handle on php files. That is not part of the forums. That is not something we have control over on the forums when it's at the user-end level. Why that matters when trying to save a file as XML, CSV or TEXT is beyond me.
Again, we need more specifics if you want some assistance. For example, clicking on the TEXT link and either saving or opening it should not invoke a PHP extension. Something would appear to be messed up on your machine.
Regardless of which of the three I choose, I get a notification that a php file is created and do I want to open or save it.
I went to a completely different computer and got the same results. The default is to a .php extension and I have no software loaded that can read/write/or otherwise process a php folder. I do not have photoparade installed on any pc in my home.
I did manage to somehow get something to go to notepad but it is a jumbled mess of characters and only covers a few of the PMs.
It should not be a PHP file. While it's possible there's an issue with the server cluster, the fact that I'm unable to duplicate the issue does not support it. I have tried numerous times, when documenting the process for you, and every time the results were as expected.
