Error message
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Error message
Can someone decipher the following error message and tell me what to do about it?? I have been getting this message continuously for three day while on CF.
Error #2044: Unhandled securityError:. text=Error #2048: Security sandbox violation: https://secure.flashtalking.com/3296...0_V3_Rich1.swf cannot load data from https://www.corvetteforum.com/forums...al-discussion/.
at com.flashtalking.princessCruises.templat e.assets::FeedXmlParser()
at com.flashtalking.princessCruises.templat e::PRI_COR_PROSPECTING_2014_728x90_V3_Ri ch1()
Please don't cross-post the same message in multiple threads. You posted this same error/message in the following thread, which is not exactly related to the discussion in that thread:
https://www.corvetteforum.com/forums...post1590283676
In regard to your issue, we will do some investigating and get back. I believe this is an issue with config for a flash ad. However, I also need to know the following:
1) What version of IE are you using?
2) Are you logged in or not when the error occurs?
I believe it might be an issue related to Flash and a configuration issue with the advertisement. Yes, likely only seeing this on Windows but I don't think it's an issue due to Windows. We're still looking into it.
