Editing Details in UserCP
So I wanted to make a change to my "Details" in UserCP. I made the change and I got an error message that said "A required field called Country of Residence is missing or has an invalid value."
I had not filled this field out at any time before (it's currently blank) and it doesn't like "US", "USA", or "United States" There is no pull-down menu for selecting a country name. So what needs to be there and why is it a required field if reasonable values are entered and not accepted?
What browser are you using?
The field selections appear to display correctly for me in Firefox, as shown. This is a simple drop-down selection, so my suggestion would be trying to clear your cache.
Yes, it's new and is required so that IB complies with your country's laws.
I'm using FireFox 41.01 which I believe is the current version.
Last edited by c4cruiser; 10-03-2015 at 03:43 PM. Reason: Edit: Got it!! restart of FF worked.
Only Administrators can change usernames. You need to contact an Administrator. You can either reply here and I'll change it or send me a PM.
Also, because CorvetteForum is over 15 years old and largely active, most common usernames are already taken.
