Help Forum How To | General Corvetteforum Questions | Feedback
animated avatar
Old 12-16-2015, 05:27 PM
ls1121
Support Corvetteforum!
ls1121's Avatar
St. Jude Donor '14-'15
Default animated avatar
I am a gold member and my animated avatar has no animation, what did I do wrong. It is a .gif
ls1121 is offline
Old 12-16-2015, 05:31 PM
J T
IB Staff
J T's Avatar
Not all GIF files are animated unless it was created as such. So was it originally animated?
J T is offline
Old 12-16-2015, 06:25 PM
ls1121
ls1121's Avatar
Yes I downloaded it to my desktop, when I open it from my desktop it animates.
ls1121 is offline
Old 12-16-2015, 08:42 PM
J T
IB Staff
J T's Avatar
Post it as an attachment here for review.
J T is offline
Old 12-16-2015, 11:18 PM
ls1121
ls1121's Avatar
Great! Here ya go.
ls1121 is offline
Old 12-16-2015, 11:28 PM
J T
IB Staff
J T's Avatar
The problem is that it's too large in dimensions, so that the software has to resize them to fit the restrictions and that's where the problem is. You can't just resize an animated GIF like a non animated GIF or JPG because an animated GIF contains frames, which all have to be edited. The forums was not really developed to do that.
Adjust it to comply on both 150 x 150 pixels while under 976.6 KB and it would work.
J T is offline
Old 12-17-2015, 06:13 PM
ls1121
ls1121's Avatar
hmmmmm ok thank you, i don't know how to do that.
ls1121 is offline
Old 09-30-2016, 08:04 AM
dvarapala
Making CFOT Great Again
dvarapala's Avatar
Sorry to bump an old thread, but I have the exact same issue. In my case, the pixel dimensions and the file size are both within the limits, but I don't see the animation in the forum.
File attached for review.
dvarapala is offline
Old 09-30-2016, 08:45 AM
J T
IB Staff
J T's Avatar
Your avatar is animated and works as designed.
The issue is your avatar runs X amount of frames then stops. It is not an infinite loop, which is an option when creating gifs.
So when you're browsing the forums, your avatar likely stops because it's not an infinite loop and it's in your browser's cache.
To fix, you would need to edit the gif and add the infinite loop.
J T is offline
Old 09-30-2016, 08:17 PM
dvarapala
dvarapala's Avatar
Thanks, that makes sense.
What threw me was that when I look at the file in IrfanView it repeats forever, so I had no idea it was non-looping.
Now where's that Thanks button...?
To animated avatar
