Help Forum How To | General Corvetteforum Questions | Feedback
Lost Post
Old 03-05-2016, 11:59 AM
KJL
KJL's Avatar
Default Lost Post
I recently started a post that was to document my C4 rear differential upgrade and flywheel swap. I uploaded a couple of pictures the other day and now I cant seem to find the post under advanced search option. What happened to it?
KJL is offline
Old 03-05-2016, 12:35 PM
oldgoat99
oldgoat99's Avatar
have you tried listing all the threads you started to see if you could find it?
https://www.corvetteforum.com/forums...rchid=53560944
oldgoat99 is offline
Old 03-05-2016, 12:40 PM
KJL
KJL's Avatar
Yes, without luck. From what I understand it is not easy to accidentally delete a post.
KJL is offline
Old 03-05-2016, 12:44 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
https://www.corvetteforum.com/forums...a-fw-swap.html
But no pics
Vette_DD is offline
Old 03-05-2016, 12:55 PM
KJL
KJL's Avatar
Originally Posted by Vette_DD
That is not the same thread. I was hoping that if it was removed by the moderator, there would be some record of it.
KJL is offline
Old 03-06-2016, 09:05 PM
savewave
savewave's Avatar
Received 1,301 Likes on 495 Posts
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
St. Jude Donor '03 thru '24
NCM Lifetime Member
I searched through threads you have started for the past five years and found nothing deleted by moderators.
savewave is offline
Old 03-06-2016, 09:50 PM
Vette_DD
Vette_DD's Avatar
OP, are you a member of more than one Corvette forum?
Vette_DD is offline
Old 03-07-2016, 11:40 AM
KJL
KJL's Avatar
Yes I am also a member of the ZR1-Net Registry. I looked there first before looking for help here. I know this is where I started the thread under the C4 technical forum as this work is not ZR1 specific. No worries though. Thanks a bunch for looking. I will just start another. Thought the info would be of some help to folks considering doing the same thing.
KJL is offline
Old 03-07-2016, 07:42 PM
Internetguru
Internetguru's Avatar
Recently my intro post disappeared. Was wondering if I did something wrong to get it deleted. Seeing this post makes me think that the Corvette Forum database has some type of corruption and is losing posts.
Internetguru is offline
Old 03-07-2016, 07:52 PM
KJL
KJL's Avatar
Seemed to happen shortly after I uploaded a couple of pictures.
KJL is offline
Old 03-07-2016, 09:00 PM
Internetguru
My entire thread disappeared when I edited and checked the show your signature box on my opening post.
I found a link to my thread in my browser history and brought it back up and unchecked the show my signature and my thread magically appeared again.
Old 03-07-2016, 09:04 PM
KJL
KJL's Avatar
Unfortunately my thread was new and just sharing technical info regarding my project and I had no responses. Good idea though.
KJL is offline
Old 03-07-2016, 10:24 PM
Internetguru
Link to the thread I lost and resurrected by unchecking the signature box.
https://www.corvetteforum.com/forums...-corvette.html
There are clearly some glitches in the CF software/database.
Weird it has disappeared once again... Oh well I wonder what other posts I have lost that I did not notice.
Old 03-11-2016, 07:57 AM
KJL
KJL's Avatar
Stumbled across my post on page 3 of the C4 technical section. Glad I found it, just going to copy text and start a new thread and also correct upgrad to upgrade. I wish there were a way to edit titles.... they appear to be forever.
https://www.corvetteforum.com/forums...de-begins.html
KJL is offline
Old 03-11-2016, 09:40 AM
J T
IB Staff
J T's Avatar
There is a known issue where posts may not get updated into the Search. While the post itself is in the database and can be viewed if you find it or know the direct link, sometimes the Search doesn't have the records. It is an issue being looked into.
Thread titles can be edited by Administrators and Moderators. If you want the thread title edited, let us know and I will change it.
J T is offline
Old 03-11-2016, 09:42 AM
savewave
savewave's Avatar
NCM Lifetime Member
When I asked the tech team about this, they told me the threads are not disappearing. The issue has to do with indexing and it's a known problem that has yet to be resolved. It seems that when a thread is edited, the software wants to reindex it to account for the update. While that should happen almost immediately, the process is being delayed. That means the thread doesn't show up in a search, even though it is right there where it was to begin with.
savewave is offline
To Lost Post
Quick Reply: Lost Post
