1970 454 Inlet Manifold - Gasket; which way up?
About to refit inlet manifold, I am using Felpro gaskets, I notice they have a front and back that is different, does it matter which way round I fit them i.e. one side has numbers stamped onto them does this side fit against the inlet manifold or the cylinder head, or does it not matter?
Please use the C3 section for 68-82 Corvettes as linked below:
https://www.corvetteforum.com/forums...performance-3/
This section is for Help with the website and account issues.
I moved your last few posts to the C3 section but since you have created more posts in the Help section, I figured you weren't aware.
