ignition switch
ignition switch
1. I installed a new ignition switch and key cylinder. I cannot get the key to go into the accessory mode.
2. I have electronic ignition, do I need to have the ballast resistor?
This sections is for Help with the Website and Account issues. This is not the section to post Corvette specific technical questions as it will not be seen by the proper audience.
You need to post in the section that covers the model year (generation) of your Corvette.
For example C1/C2 Technical forums are here:
https://www.corvetteforum.com/forums...2-corvettes-4/
C3 Technical forums are here:
https://www.corvetteforum.com/forums...performance-3/
Complete list can be viewed here:
https://www.corvetteforum.com/forums/
