Constantly getting logged off!!
your comp is probably all gummed up with **** viruses.
1) You're not using Remember Me option when logging in.
Solution: Make sure there's a check in the Remember Me box when you supply your username and password. If you don't do it, you will have to supply username/password every 30+ minutes of inactivity. This is by design for public computers.
2) Your browser is set to delete files upon exit.
Either select CorvetteForum as a Favorite and make sure Preserve Favorites Data is selected, or disable the delete files upon exit option. How you do this depends on the browser.
3) You're using 3rd party software that is removing browser files.
Solution: We can't provide support for this due to the amount of different products available and different settings.
4) You're using the log out link.
Solution: Don't use the log out link!
5) You have corrupt browser cookies for CorvetteForum.
Solution: Assuming you have a bad CorvetteForum cookie in your browser, how you delete it depends on the browser being used. There's an easy way of deleting ALL cookies for ALL sites and a more involved method of singly deleting cookies. Again, it depends on the browser being used.
What do you mean new password? If you have to reset your password because you're getting an error about an incorrect username/password, then you are absolutely not providing the correct password or username.
