My Recent Topics Issue
Enjoy while you can.
Received 2,689 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Been having the same issue...
It still works for me.
The "My Recent Topics" selection seems to record what you do right now but if you exit and come back in the history is lost and it shows no activity.
I usually check the last 7 days option and it shows zero. If I post something today it will show while I am logged on but goes away when I leave and come back.
Finalist 2021 C3 of the Year - Modified
Mine also has stopped, last 4-5 days i think its been doing this. If i post today and exit and log back in the post will not show up. But will show as long as i don't exit.
Maybe it's being phased out. Go to the top right of your screen and click on your username. Select "My Recent Posts" and it will show all for about the last 3 months. If you click on "Subscribed Threads" it will show all since the beginning of time.
At least for me it does.
They did this over on the 'LS1Tech' forum............
The admin folks are aware of the problem and hopefully will get it sorted quickly. A couple of threads on it the "Help" section.
Subscribed Threads and My Recent Posts are two very different things. Subscribed Threads could be threads you didn't even reply to, but subscribed to it to keep track of. Subscribed threads could have email notification or no email notification.
No, it wasn't. My Recent Topics disappeared, along with a few other quick links from the global navbar, just as it did here on CorvetteForum for a brief time after an upgrade. CorvetteForum was fixed early while LS1Tech is more complicated because of banner not being a typical image. It is to be fixed.
Just a question. I cannot get any response, when I click on the "my recent posts" icon on the toolbar. I can, however, get SOME older posts to come up if I go to the upper right side of the screen, and click on my username and access the pulldown there. (similar to the LS1Tech website, hence my comparison)
HOWEVER, it appears to me, that a number of my posts, that were made over the weekend, have disappeared. I even tried using the search function, using a "keyword" for one particular topic I was involved in, and nothing comes up. Do you think this will be resolved, with the posts from the weekend being "found"?
The problem is with the search engine. It's not confined to the My Recent Topics (which uses the search engine) but also the main search. Note the My Recent Topics is actually just a shortcut link into the Search.
So the My Recent Topics and Search both not showing recent content are related.
No content should be lost.
I guess you meant this:
https://www.corvetteforum.com/forums...nt-topics.html
This is the entire thread.
The "My Recent Topics" feature seems to be working again.......
