Photo's appearing in threads
I have noticed that in most of the posts that I read the contributors car's photo is displayed. How do I get my car's photo to show when I post a new question or answer? Thank you very much, Duke
Duke, are you referring to the left side AVATAR or within the post itself?
This can be set up using your profile set up by linking an image link using something like an IMG link from Photobucket.
I'd run your steps down to do this but I am on mobile and it's different I think. Let me look.....
Under USER CP down in the Settings section EDIT AVATAR / EDIT SIGNATURE.
You have an option to select a file from your computer.
Hope this helps.
Hope this helps.
Please take the time to read the Announcements and Stickies as they contain important and frequently asked information.
Your question is covered, with directions, in the following sticky:
https://www.corvetteforum.com/forums...elp-guide.html
Thank you, thank you!
Hope this helps.
Hope this helps.
Didn't know what an avatar was! That did it, thank you so much! Duke
Good reason to read the Help Guide that I linked above. It shows, with pictures, that's an avatar and also how to set it.
