Time change
Time change
Is there anything I need to do on my end to get the post times to read correctly? They now an hour ahead due to the time change. They have always adjusted by themselves in the past.
It is still automatic. But user-end options and computers will also decide what happens.
Go to UserCP and Edit Options and make sure automatically detect DST settings is enabled under Date & Time Options and the timezone is correct.
If that is checked, make sure the computer's date/time and DST is correct.
If that's correct, then you must be using 3rd party software that is blocking the JS on CorvetteForum and preventing the detected change.
