OT picture viewing problem not just XP
Reallly, with ff....hum, likely error with the photo host, see if it clears by tomorrow,
Im on ff android its fine....
Did you do any updates recently
Received 1,304 Likes
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
St. Jude Donor '03 thru '24
NCM Lifetime Member
I've followed all the links where you say you can't see pictures -- just green boxes -- and I'm able to see all of the pictures with no problems.
Microsoft no longer supports your operating system, as J T has explained to you several times. Despite that, you have posted about the issue 13 times, suggesting that you and your problem are being ignored. It's not reasonable to expect Corvetteforum to assume responsibility for supporting a product Microsoft will not support.
By your description your issue is different. And it likely is different.
What version of Firefox are you using? And please provide a link to a specific post showing the issue. A screen capture would also be great.
I'm going to guess you may have a setting issue in Firefox. Firefox (assuming it's current) and Windows 7 will work just fine. I speak as a user of that setup myself.
