Trick Flow
Old 12-30-2008, 10:10 AM
TrickFlowTech
Supporting Vendor
TrickFlowTech's Avatar
Default Trick Flow
Hi my name is Gregg. I am one of the Techs here at Trick Flow Specialties. Here are some of the products we offer for the Corvettes and other GM products. If you have any questions feel free to contact me at anytime.
Trick Flow GenX™ Street Cylinder Heads for GM LSX
AKRON, OH—More and more GM enthusiasts are turning to 4.8L and 5.3L iron block versions of General Motors' LS engine to power their kit cars, hot rods, musclecars, street machines, and sport trucks. And Trick Flow Specialties is ready to help these enthusiasts build serious street power with its new GenX™ Street Cylinder Heads for GM LSX engines.
Starting with the track-proven GenX Street/Strip LS head design, Trick Flow engineers refined the combustion chambers to retain the stock compression ratio and work with the smaller bore diameters of the 4.8L, 5.3L, and 5.7L engines. They also modified the chambers to unshroud the valves and increase airflow and swirl.
The GenX Street heads will be available in three versions:
Option One features standard cast chambers and Fast As Cast™ ports that precisely duplicate the port shape and profile of fully CNC-ported heads, and valve seat-to-port bowl blending for better transition from the chambers to the ports.
Option Two combines the Fast As Cast runners with fully CNC-profiled combustion chambers and bowl blending for improved airflow.
Option Three features fully CNC-machined and bowl-blended chambers and CNC-ported runners for maximum airflow.
In any configuration, GenX Street cylinder heads outflow and outperform factory LS6 heads. GenX Street heads are fully assembled and ready to bolt on right out of the box. The components include lightweight stainless steel 2.000" intake/1.575" exhaust valves, high lift valve springs, chromemoly steel retainers, ductile iron valve seats, and special Trick-Alloy powdered metal valve guides. In addition, these heads retain the use of all stock sensors and fittings and can accommodate aftermarket roller rocker arms. Bare cylinder head castings are also available.
Based in Akron, Ohio, Trick Flow Specialties offers products that provide "Ultimate Bolt-On Performance." Trick Flow's product lines include cylinder heads, intake manifolds, camshafts, valvetrain components, and more.
Trick Flow® GenX (TM) Fast as Cast Cylinder Heads for GM LSX
Fast as cast!
If you're looking for the best value in GM LSX performance, look no further than these Trick Flow® new GenX (TM) street/strip fast as cast aluminum cylinder heads. The GenX (TM) as-cast heads feature all of the same goodies that make the CNC-ported heads so incredible--13.5 degree valve angles, decreased valve shrouding, increased mid-lift airflow, relocated spark plugs, improved rocker arm-to-valve cover clearance, and a rigid casting design for extreme horsepower applications--but in a more affordable, as-cast version that flows nearly as much air as the ported heads
Trick Flow® GenX (TM) Street/Strip CNC-Ported Cylinder Heads for GM LS Engines
Serious horsepower for your LS-based engine.
Working hand-in-hand with our customers, the Trick Flow® Product Development Group identified the need for a high-flow cylinder head designed specifically for large cubic inch GM LSX engines. Beginning with our track-proven GenX? street/strip heads, Trick Flow® engineers refined the intake and exhaust ports to optimize low, mid, and peak lift airflow and the area under the curve for engines with 4.125 in. and larger bores. The engineers also modified the combustion chambers to further unshroud the valves and to increase airflow and swirl. With these changes, a new Trick Flow® cylinder head was born--the GenX? street/strip 235! Independent testing conducted with Vengeance Racing proved the new GenX? street/strip 235 heads deliver the goods. Their pump gas, 440 c.i.d. LSX car with a mild hydraulic roller cam and our 235 heads made over 625 rear wheel horsepower. These fully CNC-ported performance cylinder heads feature 235cc intake runners, 80cc exhaust runners, 70cc combustion chambers, 2.080 in. intake valves, 1.600 in. exhaust valves, bronze valve guides, and interlocking ductile iron intake and exhaust valve seat inserts. Assembled heads come equipped with 1.300 in. dual valve springs (for hydraulic roller camshafts up to 0.600 in. of valve lift),Viton® fluoroelastomer canister-style valve seals, 7 degree machined steel valve locks, and 7 degree titanium retainers. The Trick Flow® GenX? 235 LSX cylinder head is capable of making well in excess of 700 HP N/A, and the 6 bolt configuration ensures optimal head gasket sealing when used with a GMPP LSX engine block. These heads have been proven time and time again to be the best readily available production LS heads on the market! Made in the USA
Trick Flow Expands Line of TFX Fuel Injectors
AKRON, OH—In 2007, Trick Flow Specialties unveiled a new line of performance fuel injectors that deliver better fuel atomization, high operating efficiency, and quieter performance than other aftermarket fuel injectors. Now, the Akron, Ohio-based company has expanded the line to include the following new flow rates: 44 lbs./hr., 55 lbs./hr., 72 lbs./hr., 83 lbs./hr., and 95 lbs./hr.
"In response to the huge demand for our TFX fuel injectors, we've added additional flow ratings to our selection," Al Noe, Trick Flow Manager, said. "Our customers can now choose from ten different flow ratings to meet their performance requirements."
Also available in 24 lbs./hr., 30 lbs./hr., 36 lbs./hr., 48 lbs./hr., and 120 lbs./hr. flow ratings, TFX Fuel Injectors feature disc-type fuel control valves and improved nozzles to atomize fuel better. Low magnetic stainless steel injector bodies prevent corrosion from underhood contaminants and seal the injectors from moisture contamination. The injectors have EV1-style wiring connectors which match the OE wiring harnesses for an easy, positive connection. Viton fluoroelastomer O-rings seal the injectors to the fuel rails and intake manifold to prevent fuel and air leaks under extreme operating temperatures. TFX Fuel Injectors also include 1/2 micron filter screens to keep debris out of the injectors.
The injectors are part of Trick Flow's line of TFX Fuel System Products, which includes fuel filters, fuel pumps, fuel regulators, fuel fittings and hose, and nitrous systems and accessories. For more information on TFX Fuel Injectors--and the entire Trick Flow TFX product line—you can call 1-330-630-1555.
Trick Flow by Magnuson Superchargers
TALLMADGE, OH—To create the ultimate supercharger kits, the airflow experts at Trick Flow have teamed up with the supercharger experts at Magnuson to offer Trick Flow by Magnuson Superchargers. These complete, application-specific kits include everything you need to gain up to 150 horses!
At the core of these kits is a Magnuson roots-style supercharger upgraded with intermeshed helical rotors and special port geometry to promote smooth, efficient, and quiet operation—it's driven by less than 1/3 hp at 60 mph. The supercharger is overdriven for boost starting at off-idle, and it has an internal bypass valve to eliminate power loss at part throttle. It also features a self-contained lubrication system and satin-finished housing.
To hook that supercharger up to your engine, the kits contain everything you need (exact contents vary by application). The EFI kits include a MP112 supercharger, cast aluminum intake manifold, an air-to-water intercooler, high-capacity fuel injectors (EFI only), plumbing, wiring harnesses, brackets, hardware, and a programmer to properly calibrate your ECU. The carbureted systems come with a bare-finished MP122 supercharger and a fuel system compatible with just about any blow-through 4-barrel carburetor. They also include an aluminum intake and top plate, crank pulley, idler assembly, distributor hold-down, gaskets, spacers, brackets, and hardware.
Installation is simple thanks to the handy instruction manual complete with color photographs, and there are no hood modifications required. The kits are covered by a three-year warranty.
The EFI kits are available for the following applications:
1999-2003 Chevy/GMC Silverado/Sierra, Suburban/Tahoe/Yukon/Yukon XL
2004-06 Chevy/GMC Silverado/Sierra 2500, Suburban/Avalanche/Yukon XL 2500
2007-08 Chevy/GMC Silverado/Sierra, Flex Fuel 5.3L (J-code only)
2006-07 Chevy Trailblazer SS 2WD/AWD
2005-08 Ford Mustang GT 4.6L 3V
2004 Pontiac GTO LS1
2005-06 Pontiac GTO LS2
And now we are able to sell the Corvette kits!
TrickFlowTech is offline
Old 12-30-2008, 11:57 AM
TN 2005 C6
Support Corvetteforum!
TN 2005 C6's Avatar
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Welcome aboard.
TN 2005 C6 is offline
Old 12-30-2008, 02:27 PM
*FAÇADE*
PHOTOSHOP SPECIALIST
*FAÇADE*'s Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Welcome to the Corvette Forum!
*FAÇADE* is offline
Old 12-30-2008, 02:39 PM
ccrazor
ccrazor's Avatar
St. Jude Donor '08-'09
Welcome to the forum..
ccrazor is offline
Old 12-30-2008, 03:17 PM
LMH4C5
LMH4C5's Avatar
St. Jude Donor '08-'09-'10
National Champs Gators 4 St. Jude '09
Welcome to the forum Gregg
Lots of us will be asking questions as soon as our hobby budgets get refilled.
LMH4C5 is offline
Old 12-30-2008, 03:33 PM
Roscoe
Roscoe's Avatar
Welcome!
Roscoe is offline
Old 12-30-2008, 05:20 PM
csexton
csexton's Avatar
Welcome
Chuck
csexton is offline
Old 12-30-2008, 05:30 PM
Sabre34
Moderator
Sabre34's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Welcome Aboard!
Sabre34 is offline
Old 12-30-2008, 06:49 PM
betyelou
betyelou's Avatar
betyelou is offline
Old 12-30-2008, 07:38 PM
ALVetteFan
ALVetteFan's Avatar
Welcome to the Forum.
ALVetteFan is offline
Old 12-31-2008, 02:53 AM
traindude
traindude's Avatar
Welcome aboard!
traindude is offline
Old 12-31-2008, 06:04 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome!
Bills Z06 is offline
Old 12-31-2008, 07:05 AM
BlackZ51Vett
BlackZ51Vett's Avatar
Welcome aboard. Enjoy !!!!
BlackZ51Vett is offline
Old 12-31-2008, 07:57 AM
dsdrury
dsdrury's Avatar
Good Morning and welcome to the Corvette Forum. Best Wishes. Donn
dsdrury is offline
Old 12-31-2008, 12:06 PM
CENT Z06
CENT Z06's Avatar
Welcome. Very glad you joined!
CENT Z06 is offline
Old 12-31-2008, 02:49 PM
ugadawg77
ugadawg77's Avatar
Welcome to the forum!
ugadawg77 is offline
Old 01-01-2009, 10:08 AM
guappy
guappy's Avatar
Welcome
guappy is offline
To Trick Flow
Old 01-02-2009, 01:24 PM
LoneStar26047
LoneStar26047's Avatar
Welcome to the Forum!
LoneStar26047 is offline
Old 01-03-2009, 12:13 AM
jmoody66
jmoody66's Avatar
Im about to pull the trigger on some PRC Stage 2.5 heads....tell me what you can do, pricing wise, with these Trick Flows. Already ruled out AFR's cuz I dont see 1K per head as reasonable and the idiots wont even answer emails so they are out.
jmoody66 is offline
Old 01-03-2009, 09:53 PM
COR Wheels
COR Wheels's Avatar
Great products
COR Wheels is offline
Quick Reply: Trick Flow
