I have replaced the clutch plate, pressure plate, throwout bearing, master and slave cyclinders and bleed it several times. yet the clutch will not disengage completely. The fork moves about 3/4" on the slave cyclinder side and the clutch and break pedals do not align the clutch is about 1" lower then the break is this normal. Any thoughts on what to do to fix this. The stud the fork rest on looks a little worn could this be it?
Fred
Please post your problems in the Technical Performance section of what generation of corvette you own, forum members will be happy to help if they find your post in correct forum. Regards
