1963-1979 Corvette Spool & HD Hubs
I'm a old car guy, not a computer guy ! I came here to pickup information on C2 & C3 Corvette suspension parts, I also put a 1963-1979 Corvette 4 series Spool ( 33 spline shaft & inside the spool ) with 30 spline outer hubs its on ebay till 1-15-17 for $498.00 if anyone wants one check it out. Its a one heavy duty shaft which gets rid of the C clips you just shim in your ring & pinion spacers for the back lash you want, then put the spacers & hubs on each end bolt it together, you see from the pictures on ebay I will try to put one on here I hope !
Last edited by Prostreetlamborghini; 01-12-2017 at 04:05 PM. Reason: add a price & maybe a picture I hope
Received 1,679 Likes
Welcome to the CF!
Check out the C1&2 and C3 areas of the forum.
I'm a old car guy, not a computer guy ! I came here to pickup information on C2 & C3 Corvette suspension parts, I also put a 1963-1979 Corvette 4 series Spool ( 33 spline shaft & inside the spool ) with 30 spline outer hubs its on ebay if anyone wants one check it out.
https://www.corvetteforum.com/forums...ale-wanted-57/
Post links to C1/C2 ebay sales here:
https://www.corvetteforum.com/forums...d-c2-parts-59/
Pro Mechanic
Received 3,952 Likes
Welcome to the forum
