Colorado Emissions Standards?
I'm from Illinois, contemplating a change. I have vacationed in Colorado, and love it. I have a friend or two in Denver area and I was contemplating looking for a job and moving out of Illinois.
Onto my question: What are the emissions requirements in Colorado. Right now I have a 90 with long tube headers, no EGR or Air pump hooked up. I am running a cat. Just wondering if I did make the move what obstacles I'd have with getting the car registered/passed emissions.
Right now the car is too old for Illinois to worry about and they I don't have to worry about passing emissions. I bought the car with some mods on it, so I don't even have original parts I could put back on for testing.
Pro Mechanic
They are suposed to check for missing emissions equipment also, O2 sensors, cats, air pumps etc. if they spot something removed you have to make it right regardless of cost.
All the test centers are tied into the same data base, so they will know if another station failed you.
http://www.dmv.com/co/colorado/vehicle-registration
Registering your out-of-state vehicle will require an emissions test. In Denver and some nearby "Enhanced Area" counties, you might qualify for an emission waiver if you spend $715 in emissions related repairs, except that... "Vehicles with missing or tampered emission control devices are not eligible for an emissions waiver.
http://www.colorado.gov/cs/Satellite.../1213694692475
So, even in less-strict Colorado counties, you must have all the OEM emissions equipment -- that is, unless your Inspector is easily bribed or a sympathetic enthusiast or an incompetent employee or a moron who wouldn't know an air pump from a breast pump.
Bottom line: At the very least, you must have all the OEM emissions equipment installed. Then, either qualify for a waiver or pass the emissions testing.
Colorado is too crowded and the weather sucks here. You'd be way better off in Illinois.
Thanks for the info. I was not aware of that.
That's 1/2 true. It goes by county and Larimer county goes clear to Wyoming to the north and the divide to the West. So you can be a long way from Denver and still need to be tested.
As for crowded I don't know about Denver for sure, but Chicago to suburbs just keeps getting more and more people, hard to get away from rush hour traffic.
Hmm, I was thinking about swapping to a miniram with an engine build, that would mean I couldn't put the EGR back on.
Plus up in the mountains, Pitkin County is emissions checked.
True. And the good news is that there is no rush hour traffic between Monument and Denver. The traffic is so bad all the time that you just don't notice when it's rush hour.
Monument Colorado, 50 miles South of Denver, 12 miles north of Colorado Springs...no emissions testing at all. Brought 4 cars in when I moved here in 2007 and no emissions tests, just VIN verification, performed at/by any local car dealer.
I make the run to and from Englewood every day, no traffic...75mph, 40 minutes door to door.
After growing up in Illinois. 2 years in Washington D.C. then 2 years downtown Chicago I moved to Colorado the day after I graduated..Literally.
I live in the southwest corner of Weld county ( right next to boulder and broomfield counties). No emissions...yet.
Technically, if you drive in an emissions area you "should" be tested. My office is in south east boulder county about 13 miles away. been driving there for almost six years no problem.
I just avoid the sniffers when I see them parked on "on" and "off" ramps to HWY 36.
We have my car tuned VERY lean at idle and lean at part throttle. WOT is 13.1-13.3:1. and avg 28mpg on the bypass. I don't polute nearly as much as the 15-20 year old broncos, blazers, caprices I see driving around. not to mention the tweaking turbo diesels that leave CLOUDS of particulates driving around.
Also democrap Governor Bill Ritter has been trying hard to get vehicle emissions testing in place for presently exempt Weld and Larimer Counties. You know that already, but others need to be made aware.
true, but it hasn't changed in 6 years since I've lived here. If you haven't noticed Colorado is ready to go back to a red state the way it should be.
Yep no emissions in the Springs. Traffic does suck in Denver and between the citys. My brother just moved from S Elgin to the Springs. He loves it. Weather is way better here but you'll miss the green. It doesn't rain much here. What you will like is property taxes. They're 1/2 to 1/4 of IL insane taxes.
Larimer County (berthoud, Loveland, Fort Collins) -30-45min N of denver and Weld county (frederick, firestone, parts of Longmont, Erie...)15-20 min N of denver currently only has emmissions on desiel trucks.... BUT rumor has it they are bringing it back for gas powered vehicles in a couple years. Most other counties around denver have Emmissions.
When it comes back to larimer county, IM Screwed lol my hoopty has no chance in HELL of passing
S
S
